560 cab
Mark in MN
04-20-2005 09:02:21
Can anyone tell me if a cal for a "56" series (1456 actually) fit a Farmall 560??- Thanks
DanTo
04-22-2005 08:37:25
 Re: 560 cab in reply to Mark in MN, 04-20-2005 09:02:21
I have a cab off of a 660, don't know if it would fit a 560 or not. Would make you a good deal on it if you were interested.
ny bill
04-20-2005 18:22:08
there's a guy on red power forum that put a cab on a 560. had a picture too. i can't remember who, but if you post the question....it didn't look half bad, and kept the snow away.
Not Very Well
04-20-2005 11:36:56
Just bolting it on, it probably won't fit too well. The 560's seat is much farther back in relation to the rear wheels. Basically, you'd have to hang your butt out the back window of the cab to drive the tractor.
You would also have problems getting in and out. A 560 is meant to be mounted from the rear. So, you'd have to climb in the front door, shimmy your way back along the rear hood, then hang your butt out the rear window to drive the tractor...
