Super C Fast Hitch (mounting question)
Andrew Z
04-20-2005 13:51:16
On my 53 Super C I have the fast hitch and had to remove the arm that goes through the tool box. (the weld on the arm was starting to fail)anyway the brackets on the side of the box, had no bolts holding them to the operators platform (there were bolts only holding them to the box). After removing the brackets I found them to be snaped off. I removed the sheared bolts. Is there suposed to be a bolt that holds the side brackets on the box, to the platform?
Thanks for the help Andrew
jwh
04-20-2005 18:24:50
 Re: Super C Fast Hitch (mounting question) in reply to Andrew Z , 04-20-2005 13:51:16
Yes, mine has three on each side,two bolts into the tool box and one into the transmission cover, Jim
ny bill
04-20-2005 18:08:43
yes, there are 2 bolts on each side - 1 goes through the side of the tool box, and the other goes through the bottom angle on the strap and into the transmission top cover. hth.
