H live hydraulic pump pressure volume
Double E
04-20-2005 18:34:26
I just picked up one of the hydraulic pumps that fit in front of the distributor. Can someone tell be what is the expected pressure and volume of that pump? Just how much of an accessory or cylinder size can I drive with that?
PAULIH300
04-20-2005 18:45:46
 Re: H live hydraulic pump pressure volume in reply to Double E, 04-20-2005 18:34:26
That kind of pump on 300s/350s can be used with Fast Hitch,front loaders,backhoes,etc.So it seems sufficient enough(and it supposibly seals internally for wear over time to maintain pressure).The only thing lacking on the 300/330/350s is the relative small reservoir capacity.Lift the loader more than 8' off the ground and you start running out of fluid supply.Dont know about Hs.
Dennis Gauge
04-20-2005 19:11:51
 Re: H live hydraulic pump pressure volume in reply to PAULIH300, 04-20-2005 18:45:46
Ah the beauty of two-way hydraulics! You never have that problem.
