Singing 'C'
Dixieland
04-20-2005 18:53:37
Cranked up my Farmall Super 'C' today (first time this year)and the hydraulic is pump whinning. The hydraulic box is full of Hy Tran and I replaced the filter last year. I also replaced the hydraulic temperature gauge at the same time and today I noticed the temp got real close to hot in a matter of minutes. Everything seems to be working ok but the whine and high temp concerns me. I checked for leaks and found none. Could the pump be the problem?
Dennis Gauge
04-20-2005 19:09:12
 Re: Singing 'C' in reply to Dixieland, 04-20-2005 18:53:37
The pump is whining because the oil is being forced through the system, probably past the relief valve, because it"s normal "neutral" path is blocked.
See, when the hydraulics aren"t being used, the oil should flow straight through the center of the system right back to the reservoir. Hence the term "open center."
Have you moved the touch control levers to see if the problem goes away?
Dixieland
04-21-2005 05:51:34
 Re: Singing 'C' in reply to Dennis Gauge, 04-20-2005 19:09:12
The whine is continueus even when using the hydraulics.. You have any idea why the temp gets so high?...thanks...Dixieland
Dennis Gauge
04-21-2005 07:21:26
 Re: Singing 'C' in reply to Dixieland, 04-21-2005 05:51:34
Yep, the oil is being forced through the releif valve all the time at high pressure, so it can't cool down.
