Differences in 39 H or M and later models
Okla Kansan
04-20-2005 19:00:03
aAre there any differences between the 39s and those comeing later? Like my 32 F-20 has a different steering box on top the steering column than later 20s
Jon Aller
04-21-2005 05:53:19
 Re: Differences in 39 H or M and later models in reply to Okla Kansan, 04-20-2005 19:00:03
On an M; Oil filter housing, rocker arms, front engine mount, entire pto assembly, front gas tank support, seat assembly, transmission cover.
Plus the other things mentioned below.
THEkyroastnear
04-20-2005 20:17:04
i have read articles that say the belt pulley is on the opposite side on a 39 never seen one though
THEkyroastnear
04-21-2005 19:57:32
 Re: Differences in 39 H or M and later models in reply to THEkyroastnear, 04-20-2005 20:17:04
thanks rusty for clearing my earlier statement up i would never intentionally tell some one wrong
RustyFarmall
04-21-2005 06:46:25
The belt pulley is on the same side, but the lever for engaging it is oriented to the opposite direction.
Okla Kansan
04-20-2005 19:34:40
I should say. it has the doamed top WITHOUT the bolts running through it
Sloroll
04-20-2005 19:09:08
The opperator platform is different on the 39H as is the seat and frame. I'm sure there is more. Does your F-20 have the duckbilled front like the picture Nebraska Cowman posted below or the dome top? The later F-20s had the bolts running all the way through that casting.
Okla Kansan
04-20-2005 19:32:45
 Re: Differences in 39 H or M and later models in reply to Sloroll, 04-20-2005 19:09:08
Slorol, IT has the domed top. Dont know that ive ever seen a Duckbill here. I couldnt see it in the pics Harold sent either, just showing the rear, and it loaded from a distance. All the 20s and 30s Ive ever had had the dome with bolts running through it
Nebraska Cowman
04-21-2005 02:14:32
 Re: Differences in 39 H or M and later models in reply to Okla Kansan, 04-20-2005 19:32:45
like this? third party image
But yes, to answer your first question. There are all kinds of little differences in the early H & M models. PTO shaft, Shutter control, starter switch, magneto ground switch, front grill, radiator cap, just to name a few.
