Cracked head sealer?
dr.sportster
04-21-2005 09:01:25
Hi gents,I was just rereading the posts about the cracked heads.What about the Moroso Ceramic engine sealer.Anybody tried it?I know the upstate NY dirt modified racers used it on Chevrolet big block aluminum heads with good results.Think it will work on tractors??
ChadS
04-22-2005 08:15:44
 Re: Cracked head sealer? in reply to dr.sportster, 04-21-2005 09:01:25
Sodium Silicate. Or egg preserver works very well in cracked heads, blocks water leaks in engines. Ive had good luck with it. I ve used the Moroso chemical sealer, you have to pressurize the cooling system and force it through the system, and let it set up. Chad
gene b
04-22-2005 03:06:32
I dont know what the name is just what the engine builder said. He has used it several times with flying colors. Had a head off a 113 engine with small crack on manifold side went into the edge of combustion chamber then out and he said it would be easy. I was selling tractor with new sif foot mower and didnt want any problems later. Will use that head some time in an engine i will keep.
gene b
04-21-2005 10:18:35
A lot of it would be how bad the crack is and where guy in machine shop swears by it. A puller friend of mine used it with good results. There is also a liquid when poured in small crack that works good. Could always change heads if it doesent work.
dr.sportster
04-21-2005 19:17:57
 Re: Cracked head sealer? in reply to gene b, 04-21-2005 10:18:35
Gene is that other product called Seal-Lock?? I have a bottle of that for setting valve guides and its supposed to be a crack sealer also.Seal-Lock fluid weld?Have you used it in other applications?
MagMan
04-21-2005 09:25:29
Link
