766 Transmission Oil Tell-Light...Working Right?
Mark B in TN
04-21-2005 17:57:22
I recently purchased a 766 IH. The transmission oil tell light burns whenever the clutch is in. Otherwise, it stays off.
All I have found in the manual is that the light is supposed to go off soon after starting.
The reservoir is about 1 gal low (out of 20+).
What is the experience of anybody who has one of these, or a 966 or 1066? Thanks.
Mark B in TN
04-22-2005 18:06:54
 Re: 766 Transmission Oil Tell-Light...Working Righ in reply to Mark B in TN, 04-21-2005 17:57:22
Thanks gentlemen.
the tractor vet
04-21-2005 19:17:25
The lite is suppose to come on when you push the clutch down as the dump valve is working to dump pressure off the clutch packs in the T/A for ease of shifting .
David A. Hodson
04-21-2005 18:06:05
my 766's light comes on whenever I depress the clutch and so does my 886 on the 8 it even comes on when you shift TA David
the tractor vet
04-21-2005 19:19:36
 Re: 766 Transmission Oil Tell-Light...Working Righ in reply to David A. Hodson, 04-21-2005 18:06:05
If your lite is comming on when the T/A is shifted then it will not be long before you will be fixen it as there is a pressure lose some where or your pump is getting weak.
David A. Hodson
04-22-2005 05:44:48
 Re: 766 Transmission Oil Tell-Light...Working Righ in reply to the tractor vet, 04-21-2005 19:19:36
I should've said light flashes on the 886 when shifting TA but not worried about it been doing it since tranny was rebuilt A-Z including pumo and TA 2 years ago and engine a year ago. David
Allan in NE
04-22-2005 05:51:38
 Re: 766 Transmission Oil Tell-Light...Working Righ in reply to David A. Hodson, 04-22-2005 05:44:48
Hi Dave,
Not to worry, sometimes that light will "blink" at ya when you throw the lever.
Heck, that ones even in the owner's manual. Perfectly normal and they did it when they were new. :>)
Allan
scot_c
04-24-2005 17:36:39
 Re: 766 Transmission Oil Tell-Light...Working Righ in reply to Allan in NE, 04-22-2005 05:51:38
that red light by the key? it comes on when we hit the clutch on any of out 56 and 66 series, and flashes when moving the t/a lever. All our t/a's last at least through their warranty period too.
the tractor vet
04-22-2005 07:15:50
Yea they will try and tell ya that but it is because there is a pressure lose and this happens when you have to much clearance or a weak pump if the end play on the T/A is to great then you can have a loss in the lube baffel or it got bent or a leak between the sealing rings and if his problem started AFTER work was done then SOMEONE SCREWED UP PERIOD. NO IF AND'S OR BUTS ABOUT IT.,
David A. Hodson
04-22-2005 05:59:46
mornin Allan got any planting done I got rained out, I'm not worried about the light shoot it didn't even work on the old 766 for years, but thanks anyway glad to hear from you David
