How to??
iester
04-21-2005 18:30:48
350u..How do you remove brake backing plate from rear housing?? Thanks,Lester
Jim Barrett
04-22-2005 08:49:42
 Re: How to?? in reply to iester, 04-21-2005 18:30:48
Does anyone have a electrical schematic for a Farmal H 1948 that is converted to 12 volts? I had one but cannot find, any help would be greatly appreciated. Thanks
TDK
04-21-2005 21:16:10
The bull pinion seal should be changed. It's easier to do if you remove the backing plate. If you do remove it, be sure and replace the o-ring.
TDK
04-21-2005 19:23:14
There's two threaded holes that you can put bolts into and screw them in, a little at a time, to remove backing plate. The only thing holding it is a large o-ring.
iester
04-21-2005 20:09:19
 Re: How to?? in reply to TDK, 04-21-2005 19:23:14
Thanks TDK, Was curious..No need to do that unless i have a bad o-ring,Leaking into brakes,is that right??
