Super C Fast Hitch lift Question
Andrew Z
04-23-2005 17:45:44
On my Super C I changed the O rings in the cylinder today. It will lift a load fine but if I jump on the hitch it will bounce alittle. I think I have air in the system. Is there a way to bleed the system? Thanks for the help Andrew
RayP(MI)
04-24-2005 18:13:01
 Re: Super C Fast Hitch lift Question in reply to Andrew Z , 04-23-2005 17:45:44
Air on some other systems has worked out all on it's own, just use the system & keep it topped off.
El Toro
04-24-2005 03:36:54
I forgot to mention the recommended engine speed should be 650rpm's while bleeding the hydraulic system. Hal
El Toro
04-23-2005 17:55:52
To bleed the system move the control levers back
forth 10 or 12 times and then check your hydraulic oil level. Should be an 1/2 inch below the filler opening. Add hrdraulic oil if needed.
Hal
