5488 Transmission
J I Case
04-24-2005 14:24:49
5488 transmission ranger shifter stopped working yesterday. Only range that does not grind when the clutch is released is reverse. Anyone know what is going on ?? Had this simular problem a few years ago and the dealer put a "kit" conversion in the tractor about a $500 part. Any ideas ??
Thanks in advance
chadd
04-25-2005 09:02:33
 Re: 5488 Transmission in reply to J I Case, 04-24-2005 14:24:49
The only kit that I can think of the Case IH offered for IH products would be the replacement of the sprag type Torque Amplifier unit with a Mechanical-Diode type Torque Amplifier clutch. It is supposed to just make the TA handle more stress and take longer to wear out. To me, it sounds like your range shifter went out of adjustment, or that the fork in the range trans. broke or bent. I am no expert on the 50 series tractors though. Good luck.
binderpower856
04-25-2005 15:45:27
 Re: 5488 Transmission in reply to chadd, 04-25-2005 09:02:33
There's no Torque amplifier in a 5488. If I were a betting man, I say you've shelled out a set of synchronizers or even the main engine clutch has let go. The main engine clutch is a wet-type clutch pack, and there was an "update kit" that got put on a lot them back when the tractors were fairly new, mid to late 80's. I don't know exactly what the difference is between the old style and the "updated" style, but usually the update fixes them for good...
