Rear Main Bearing??
460
04-24-2005 19:50:24
Can any one tell me if and how to change the rear main bearing in a farmall 340 tractor with out removing the engine from the tractor? And how many cam bearings dose it have? tractor has real weak oil pressure 7# hot at high RPM Thanks!
El Toro
04-25-2005 03:30:26
 Re: Rear Main Bearing?? in reply to 460, 04-24-2005 19:50:24
I think you should pull the engine after reading your previous post on the pistons. Cam bearings
are very important for good oil pressure. Take the block and have it degreased and new cam bearings installed. Your crankshaft needs to be measured and the head should be refurbished.
You need to inspect the camshaft for worn lobes.
I had a teacher in school that said: "anything
you do, do with all your might because anything done by halves is never done right". Hal
