Piston???
460
04-24-2005 19:55:52
Just got deeper in to my 340 engine and found a busted piston its stamped on top 374478R2 made by Zoler is it a common piston where can I find 2 good used ones? Need help. Thanks!
the tractor vet
04-24-2005 20:57:09
 Re: Piston??? in reply to 460, 04-24-2005 19:55:52
With what you have said you might as well pull the engine and do a major overhaul with bacd oil pressure and needing two pistons i'll bet that the sleeves have a good top ridge . and for around 500 buck for the kit .
