Need Help: F-12 Brake Drum Removal
Dan Oehmke
04-24-2005 20:09:24
Can anybody tell me the trick to removing the brake drums on an F-12? The manual says to "remove them", which is about as helpful as the other common phrase "removal is self-evident. Actually, this looks pretty straight forward, but I'm still sutck.
I have removed the big nut on each shaft. Tried to use two 3/8 bolts in the two holes in the right drum to pull it off the splined shaft, but it won't budge. This one has been outside for sometime without the brake cover. Even broke off a grade 8 bolt and called it a day after getting that out. Can I heat the drum around the splines or will that damage the shaft?
Pale Rider
04-25-2005 02:13:54
 Re: Need Help: F-12 Brake Drum Removal in reply to Dan Oehmke, 04-24-2005 20:09:24
You know Dan....I had the same problem when I first got mine home. The left wheel was frozen, a fact the previous owner "had forgot about". I remember how the spikes dug into the gravel the moment it slid off the trailer as I tried to winch it back into the garage. It certainly set a tone of doubt as to the whole project as I wondered how to get the thing out of the way if this didn't work out as I had planned.
I strove mightily after removing that large nut you spoke of, no small task in itself as I needed to buy a 1 5/8 special air socket and used a huge cheater bar on a 3/4 ratchet. After removal the drum seemed as solidly fixed as before. I remember straining and prying until I was sure I'd destroy the workings I knew lay within the drum. In the end the fix was remarkably simple and which I hit upon only after failing to literaly "break" it loose with a pry bar. As I lay there panting with an mounting sense of alarm, I looked at the linkage that was used to set the brake. I took a large vise grips and clamping the pivot that the linkage rotated on I spun the linkage as if i were releasing the brake. Counter clockwise if I remember right but check for yourself to be sure. It was rusty but rotated with surprising ease. After that, the drum came off with very little resistance. The shoes were locked against the side of the drum and rusted in position. Possibly for decades. Once rotated back to the release position my problems were solved.
It was the first thing I did to that old tractor and seemed like a huge mile stone. I hope it works for you as well.
Dan Oehmke
04-25-2005 19:22:03
 Re: Need Help: F-12 Brake Drum Removal in reply to Pale Rider, 04-25-2005 02:13:54
Hmmm. Good point on trying to release the shoes. Now I just have to wait to get to the weekend for more tractor time. Couple fellows on the ATIS list suggested heating with a torch. The only thing that would get damaged would be the seals on the shaft, but that they'd need to be replaced anyhow. Use some bolts in the holes to crank down a bit each time I heat it. Bang the drums a bit with a large hammer and I'll make sure to try and get the shoes released too. So with a little luck I'll save the shoes, which sounds like they often break if things are really stuck.
