Hey Marble eye
kev@ia
04-25-2005 06:32:17
If its a 544 gas utility it should have a fuel pump, and a solinoid shut off on the carb.
Will check owners manual to see if the farmall had the pump.
marble eye
04-28-2005 18:00:02
 Re: Hey Marble eye in reply to kev@ia, 04-25-2005 06:32:17
I took the carb apart and there was a small piece of rust covering the hole from the shut off.after cleaning the carb I bolted it back on hit the switch and the engine started and runs fine. thanks for everone's suggestions Marble Eye
marble eye
04-25-2005 14:19:28
kev The 544 I have is a row crop It has a shut off on the carb and IH dealer replaced it when they rebuilt the carb and is working
marble eye
04-25-2005 19:11:57
 Re: Hey Marble eye in reply to marble eye, 04-25-2005 14:19:28
I can spray carb cleaner into carb and it runs fine but when I stop the engine stalls.Could there be a piece of dirt or rust in the carb that didn't flush out in the rebuild? any suggestions would be great
