Super C throttle/ Governor
Andrew Z
04-25-2005 14:02:24
On my Super C the governor will respond good when the tractor is put under load. However it will not come back down in RPM's after the load is off it will be stuck at a higer RPM than the throttle was set at. I a ready replaced the bearing in the governor. I think that the governor spring is tired? Could this cause this problem??
Thanks Andrew
Bob
04-25-2005 18:49:32
 Re: Super C throttle/ Governor in reply to Andrew Z, 04-25-2005 14:02:24
Check the adjustment of the linkage between the governor and the carburetor.
CLIFF
04-25-2005 14:22:07
I would try the spring first BUT it sounds like your gov weight pins are worn and kno't letting the weights come back to rest or the shaft is worn a grove in it were the bearning you replaced is and its hanging up.
