Shift Pattern for a Farmall H
Samantha Hawkin
04-25-2005 21:00:07
By any chance would anyone know what the shift pattern for a 1944 Farmall H. It has no plate or anything else to give us the pattern Can anyone Help please..
Thank you
Shifty McGillicuddy
04-26-2005 10:47:07
 Re: Shift Pattern for a Farmall H in reply to Samantha Hawkins, 04-25-2005 21:00:07
Worst case scenario, you could've simply driven the tractor if that was possible. The gear that makes it go backwards is reverse... Slowest gear is first, next slowest is second, and so on... Let the clutch out and the tractor stalls... That's 5th. By the time you get to second, you should have a pretty good idea of the gear shift pattern, though...
Farmer Bob
04-25-2005 21:12:54
Here it is
R 2 4
-Neutral-
1 3 5
Samantha Hawkins
04-25-2005 21:17:13
 Re: Shift Pattern for a Farmall H in reply to Farmer Bob, 04-25-2005 21:12:54
Thank you Farmer Bob
