Touch Control unit
Marvin
04-26-2005 11:03:35
Is the Touch control unit for a Super A the same as that for a Super C?
When rebuilding a Touch Control Unit, does one just need to get a rebuild kit from a dealer? Are they still availble? Any special tools required to rebuild?
Front implements dropped about every 10 seconds and then relift, so I assume a bad Oring or something to that nature.
Jim Becker
04-27-2005 20:25:17
 Re: Touch Control unit in reply to Marvin, 04-26-2005 11:03:35
The big thing is to keep everything CLEAN.
Dave_Id
04-26-2005 11:39:13
Yes, you can get the rebuild kit from IH. It's over $100 bucks for a bagfull of o rings and gaskets. You can rebuild yourself, but you need a real good picture of the blow up, and you need to take special care in laying out everything on a bench just the way you took stuff out. It looks very confusing, but if I did it, so can you
Dixieland
04-26-2005 11:16:32
They have the same hydraulic box! Rebuildin one could be a challange but I'll bet you can do it. The kits are available...good luck
