706 Head Temp. Gauge
Farmallion
04-27-2005 05:31:37
Taking the tractor apart last night, i noticed that there was a Temp sensor mounted into the top of the head and it went to a temp. gauge mounted on the side of the tractor. Is this factory? if not where is the temp. sensor in the top of the head suppose to go?
Farmallion
04-28-2005 08:14:27
 Re: 706 Head Temp. Gauge in reply to Farmallion, 04-27-2005 05:31:37
Thanks Guys, looks like i need a new temp. and gas cluster gauge.
K.B.-826
04-27-2005 16:40:38
From the factory, it would have had a "mechanical" style temp gauge in the right side of the dash, in the same cluster as the fuel gauge, oil pressure light, and the charge indicator light. The temp gauge would have a tube filled with liquid running down to a sensing bulb screwed into the right side of the head. These worked fine until the tube got damaged, then most guys would just buy a temp gauge and mount it somewhere rather than replace the whole cluster. Sounds like the location of your sender is correct, but the gauge is not.
caseyc
04-27-2005 07:17:57
is it located about half way on the intake side right on top? mine has the same thing. must be factory.
casey in SD
Farmallion
04-27-2005 07:20:50
 Re: 706 Head Temp. Gauge in reply to caseyc, 04-27-2005 07:17:57
casey, do you also have the temp. gauge mounted on the side of the tractor?
caseyc
04-27-2005 07:53:59
 Re: 706 Head Temp. Gauge in reply to Farmallion, 04-27-2005 07:20:50
no i do not. the gentleman i bought my 706 from liked to customize things to his own liking. he has a temp gauge in the dash the same size as the tach on the right side. (original tack on left).
casey
