Order Farmall Cub Parts Online
Cub Compression Problem
Ted A Neis
04-27-2005 14:07:08
I have a 1949 Cub that is in real nice condition except it won't run. I have narrowed it down to compression I think?? I am at 8000ft altitude in Colorado and I realise that creates some issues. But I can't seem to get more than 30# compression. I also have a 1950 Cub and that one gets 50# & I have not done any work to it . The 49' had 0 -10 # when I got it, the valves were toast . I replaced the valves, reserfaced the seats and put in new rings and rod bearings I have the head torqued to 45# just like the book says. But I still can't get more than 30# the book says 120#, at my altitude I would be happy with 80#.I don't know what to do next unless the head is warped, I have heard that can be a problem with Cub's .
Any suggestions???? Any and all help is appreciated.
Ted
janicholson
04-28-2005 06:35:52
 Re: Cub Compression Problem in reply to Ted A Neis, 04-27-2005 14:07:08
Sorry forgot it was a flathead cub, no V/cover on top, V adjust cover is on side. (still works the same.
JimN
MagMan
04-27-2005 15:50:29
also how about the valve are they adjusted right Get it at top dead center and put air in the spark plug hole with the compression hose and a little home made deal and se if she holds the compression .And what big dog sais too. Maybe the rings are just froze up to the piston a little usally theyre seat after you run them for a while. Take you head to a machine shop and have them put it on there straight table to see if its warped and shave it if its not to bad. Just a few thoughts
Ted Neis
04-27-2005 17:28:15
 Re: Cub Compression Problem in reply to MagMan, 04-27-2005 15:50:29
Magman,
Thanks, I will try that!!!!! !!!!!
Ted
Bigdog
04-27-2005 14:34:59
are you taking dry or wet readings?
Ted Neis
04-27-2005 17:26:21
 Re: Cub Compression Problem in reply to Bigdog, 04-27-2005 14:34:59
Bigdog,
Dry
Ted
janicholson
04-28-2005 06:31:38
 Re: Cub Compression Problem in reply to Ted Neis, 04-27-2005 17:26:21
The other answers might be the ticket, But I would rather believe there is some other issue before teardown (again). Three items come to mind (45years of Wrenching) 1] THE COMPRESSION GAUGE IS TOAST??, 2] the valve timing gears have been assembeled wrong (out of time valves will cause this directly, and with the v/cover off it is simple to observe the approximate correct valve action. If the distributor/mag has not been removed, the spark will occurr at a wrong point in the rotation, no where near the timing mark), 3] the throttle is closed tight (idle secrew out, and throttle closed) sucking a partial vacuume will also indicate very low comp.
LOL jimN
