farmall super H
ringen 73
04-27-2005 17:30:48
Just bought a 1953 Super H for tractor pulling. Just acouple of questions,is this a competitive tractor and this one has power steering, is this an after market option? Thank you for time!
560Puller
04-27-2005 17:42:14
 Re: farmall super H in reply to ringen 73, 04-27-2005 17:30:48
I started out with a 53 Super H, it was a competitive tractor in 4000 and 4500 lb classes.Since I have been pulling my 560 I've retired the Super H. My two cents. Eric
Andrew Z
04-27-2005 18:31:55
 Re: farmall super H in reply to 560Puller, 04-27-2005 17:42:14
I'v seen quite afew Super H pull in a stock class and do good. I would pull it a few times to see what she can do then go into modifing. Andrew
560Puller
04-27-2005 18:18:14
560Puller, any helpfull ideas on setting the Super H up to worry all the green colored tractors?
RustyFarmall
04-28-2005 07:10:31
 Re: farmall super H in reply to 560Puller, 04-27-2005 18:18:14
A friend of mine runs a super H in the local pulls, rebuilt the engine using all stock replacement items and made sure that everything was as close to perfect as possible. He got the attention of the green boys first time out, after just a bit more fine tuning, those green boys are now accusing him of cheating. If I remember right, the super H dynoed at 46 HP, right after the rebuild.
ringen 73
04-28-2005 19:31:58
 Re: farmall super H in reply to RustyFarmall, 04-28-2005 07:10:31
Thank all you guys for answering my question. If any one has any advice on set ups for this tractor I'm all ears. I'm just getting started into tractor pulling because my dad pulls a 1936 L Case and his health isn't what it use to be. I just want to have some fun with him while I can! Thanks again
