International 254 glow plugs
thelma
04-27-2005 17:57:09
When I hold the switch to position for heat to glow plugs the indicator beside the key switch does not light up as it should, holding for 15 seconds. When this switch is held to heat I read 12 VDC at the glow plugs, but they do not get hot. Is the problem in the resistor indicator?
Tip
04-28-2005 10:49:45
 Re: International 254 glow plugs in reply to thelma, 04-27-2005 17:57:09
Sounds like you may have bad glowplugs. Pull one and put it on a known 12 volt battery and see if it heats up. If it doesn't, you need new plugs.
Regards, Tip
