Plow tire and rim size?!?!?!? How to measure?!??!
farmallkid From
04-27-2005 18:46:06
I got a 3 furrow drag plow on rubber, the back tire and rim are shot. The center plate of the rim is still ok, so i figure i can get a new rim, cut the plate out and weld it back in the new rim. The tire size is 3.50-12. I am looking in the miller tire book and cant find a tire that size. Also wandering what size rim? How do you measure a rim? If miller dont have anything i need, would they be able to get it? or do i start lookin for plow wreckers somewhere. Thanks for any info.
MagMan
04-28-2005 03:25:10
 Re: Plow tire and rim size?!?!?!? How to measure?! in reply to farmallkid From Ont,, 04-27-2005 18:46:06
Go look around the nearest salvage or a neighbor you dont like.lol I took mine off a sickle bar mower that I had here. JON
Josh H
04-27-2005 18:50:15
I was in a similar situation. I found a 3.50-12 but it was expensive. I found a 4-12 much cheaper, and used that. It works and looks fine.
jossette
04-27-2005 18:50:09
12 inches high and 3 1/2 inches wide
measure where the bead sets in the rim up and down and across.
