Farmall A (1941) implements
Scott Lathrop
04-27-2005 18:46:58
I got no response to my brushog inquiry. So, how do I mow my acre and a half of grass hay?
Scott Lathrop
04-28-2005 06:21:11
 Re: Farmall A (1941) implements/bushog in reply to Scott Lathrop, 04-27-2005 18:46:58
Wow, thanks for the responses. How can I get a 4 foot bushog?
LookInTheBookDOTcom
04-28-2005 08:45:01
 Re: Farmall A (1941) implements/bushog in reply to Scott Lathrop, 04-28-2005 06:21:11
New? Look in your yellow pages. There has to be at least one place in your area that deals in high-end lawn-and-garden equipment, a Tractor Supply, or a farm equipment dealer... If you can't find new ones for sale in your area, you ain't tryin'.
Used? Well, that's a little tougher, and you're gonna have to do some legwork. Check your local classifieds. Check the classifieds and photo ads here. Post a wanted ad in the appropriate place on this site (probably not really effective, but ya never know).
NDS
04-28-2005 04:26:44
 Re: Farmall A (1941) implements in reply to Scott Lathrop, 04-27-2005 18:46:58
Mowed 5 acres pasture with 1941 A and 5 ft. drawbar pull bush hog for 10 years. Worked fine but 4 foot would have been better as I had to take less than full cut in heavy grass. As for offset PTO just hook bush hog off center directly behind PTO makes cutting aroun trees and along fences easier too.
MagMan
04-28-2005 03:22:23
Most bushhog mowers have at least a 35 hp gearbox rating. And are a little big for an A Heck My 4 footer is enough for my H go with the belly mower much better choice. Or a sickle I guess. MagMan
gene b
04-28-2005 03:19:51
There is more than just mowing hay. What do you want to do with it after you have mowed it. If you want to bale you need a sickel mower. You can get a pull behind or a drawbar mount. If you dont want it you could use a rotary type. If you want to keep it short then a belly mower would be great/ Your call.
tinyy
04-28-2005 00:54:08
You can use a belly mower or do what I did took a three-point-hitch mower and made a hitch for my A and use that
jossette
04-27-2005 20:07:48
cyclebar ??
