Manure Spreader
Ted Womack
04-28-2005 04:46:14
Looking for an older International manure spreader for use with a 41 BN tractor. Would like to have near that time era.
Yugrotcart
04-28-2005 16:16:53
 Re: Manure Spreader in reply to Ted Womack , 04-28-2005 04:46:14
third party image
Here's what I have for a spreader, an old New Idea ground driven model. Not a large capacity, but it does the job for our 10 cows.
jossette
04-28-2005 05:05:05
third party image
this new idea is old and in working condition but not that old..
dave from MN
04-28-2005 14:29:18
 Re: Manure Spreader in reply to jossette, 04-28-2005 05:05:05
I have one identicle to it that was left here. Guy said if ya fix it up it is yours. Just needs a floor and some paint and a new jack. How many bushels to they hold and are they good spreadrs?
jossette
04-28-2005 14:58:29
 Re: Manure Spreader in reply to dave from MN, 04-28-2005 14:29:18
third party image
the 1/2 inch rod welding
JR in TX
04-28-2005 15:55:20
 Re: Manure Spreader in reply to jossette, 04-28-2005 14:58:29
Hey, what model is that one? I have one just like it and was told it is IH, but all I can find are casting numbers. It is a pto drive and I need seals for the gear box, but don't know what to look for. Thanks. JR
jossette
04-28-2005 16:26:14
 Re: Manure Spreader in reply to JR in TX, 04-28-2005 15:55:20
hit the (EXPAND) to see all the pics..
should be a plate on the bottom left of the front and a plate on same side in the back by the beater
jossette
04-28-2005 14:56:49
third party image
this is model 213 ratcheting spool and it holds a whopping 180 bushel. there is 5 positions and if your beater is rounded off, just weld 1/2 inch rod on them and she works good. there are 3 identical pauls on the racheting spool so if your does not work in 2nd or 3rd, take one off the top of the spool and put in it in the engauging spot. just got done spreading 8 loads and it leaves a 12 to 14 ft spread.
