706 Load Control
Farmallion
04-28-2005 08:19:38
The control that moves the fast hitch up & down works fine but the lever that adjusts the light to heavy will not move, its stuck on heavy. Any idea's why?
Old Dutch
04-28-2005 13:24:48
 Re: 706 Load Control in reply to Farmallion, 04-28-2005 08:19:38
Be very careful excercising that lever if it is frozen with rust. It will twist that shaft off slicker than you can believe. That becomes a major problem that will become very expensive to replace. Replaced many of them for that very reason.The friction discs become frozen from dissuse. Good luck.
Allan in NE
04-28-2005 08:32:28
FM,
Loosen that friction clutch at the lever base and see if it will move then. Might be stuck and rusted up from non-use.
Allan
David A hodson
04-29-2005 18:10:22
 Re: 706 Load Control in reply to Allan in NE, 04-28-2005 08:32:28
Allan never use mine on the 766, or 886. David
