'62 IH 404 Rear Axle
62-404
04-29-2005 07:56:01
I am in the midst of replacing the rear axle seals on my tractor and due to age/neglect, one of the axles is no good after separating the hub from the axle. I got a replacement axle & hub from Central Tractor however upon separation (100 tons pressure!) the hub shattered and axle is deformed enought that it won"t go into a known good hub. I need to get another axle asap so I can put this thing back together. The IH # is 369392R1, 27 1/2 inches long, 22 splines on outer end, 16 on inner. Anyone got any suggestions? Many thanks!
62-404
05-02-2005 04:50:35
 Re: '62 IH 404 Rear Axle in reply to 62-404, 04-29-2005 07:56:01
Never mind - I tracked one down (the 3rd replacement for this project!) and the rear axles are back together...Now if I could only get the hydraulic assembly back from the shop re-sealed!
