Farmall H 3 Point Questions
Scott Swanson
04-29-2005 08:03:05
I am thinking of throwing a three pint hitch on my 1946 Farmall H. I am having difficulties locating plows and discs and think the updated hitch will make my plow/disc hunt easier with new technology.
Any suggestions or concern I should have? Any manufacturer's recommendations?
Is the Saginaw a good one to go with?
Thanks,
Scott
riverbend
04-29-2005 11:14:17
 Re: Farmall H 3 Point Questions in reply to Scott Swanson, 04-29-2005 08:03:05
I think that if I had to do over again, I'd go with the Saginaw. That one will let you keep the original drawbar. The aftermarket drawbar that I got for my 3 point is pretty flimsy.
As far as equipment, try an ad in some of your local (rural) weekly papers. I have had very good success finding everything from a 2 bottom pull type plow to a soybean spiral.
Even with a 3 pt., I'd go with a pull type plow (i.e. JD 44 2-16) since you will not have any kind of draft control. A pull type works pretty good, cuts through and covers lots of trash, and can be adjusted to make nice even furrows. It does have some trouble taking full slices on side hills. They made a ton of them and parts are easily available.
I am keeping an eye out for a wheel disk to cut down so that my H is be able to pull it. Most of the small 3 pt. disks look like toy accessories for an atv. If you pick up more than about 500 pounds with the three point, the front end get a little light.
Nathan in Texas
04-29-2005 09:36:18
I agree. The saginaw hitch sounds like a really good setup but is going to run you $700. Even used 3 point hitch setups go for $500.
Financially the best choice is to either buy drag type equipment or sell your H and buy a newer tractor. Most of the 300's and 400's already have the 3 pt conversion on them and the 460's and 560's came with 3 pts. The 300 - 560's run just $500 or so more than the H and M's around here and you get a tractor that is 20 years newer and has live hydraulics and live pto plus the 3 pt hitch.
Of course if you like the H and want to keep it then it is a personal decision and not a financial one and the saginaw is a nice good looking 3pt hitch.
My 2 cents....
Nat
04-29-2005 10:31:12
 Re: Farmall H 3 Point Questions in reply to Nathan in Texas, 04-29-2005 09:36:18
IH didn't come out with 3pts until the 706/806 series tractors. The 460/560 still has a straight drawbar, or a fast hitch.
old
04-29-2005 09:29:38
I don't see why you have a problem finding pull type equipment. Shoot I have 3 pull type plows and 2 of them are for sale, and as far as disc. there out there if you just look enough. Post an ad looking for them. For what it would cost for a 3 point you should be able to buy a plow and a dosc. and almost a brush hog to boot
Trikeman89
04-29-2005 09:39:31
 Re: Farmall H 3 Point Questions in reply to old, 04-29-2005 09:29:38
I am in the same boat here. I cant find pull type equipment. I hate to spend the money on the 3pt but I dont see any other way. I am looking for a brush hog and maybe a plow. I live around the Kansas City, Kansas area. Just not much around here. Hey old, where are you located at? Are you close?
old
04-29-2005 10:04:26
 Re: Farmall H 3 Point Questions in reply to Trikeman89, 04-29-2005 09:39:31
By the way I can also show you how to build a 3 point I made one for my 77 oliver because I needed one but didn't have the money to buy one
Trikeman89
04-29-2005 10:38:41
 Re: Farmall H 3 Point Questions in reply to old, 04-29-2005 10:04:26
That would be great. It would be great for you to show me how.
old
04-29-2005 10:02:31
Are you on the Missouri side of KC?? If you are your only about 200-250 miles from me I'm at the lake of the ozarks, theres also a tractor pull in Eldon this saturday by the way. I have 3 pull plows and a 6 foot brush hog brand hog with a heavy duty gear box. Drop me an e-mail and I'll give you my number so we can talk
Trikeman89
04-29-2005 11:51:36
 Re: Farmall H 3 Point Questions in reply to old, 04-29-2005 10:02:31
I am on the Kansas side. Pretty close to the Kansas Speedway. I sent you an email. Look forward to hearing from you.
dhermesc
04-29-2005 15:11:36
 Re: Farmall H 3 Point Questions in reply to Trikeman89, 04-29-2005 11:51:36
Get yourself a copy of "Grass and Grain" published in Manhattan Ks. They list auctions for the entire state and haveto have at least 75-100 sales listed per week. They also have a pretty good classified section for farm equipment, usually about 3-4 pages of "For Sale" adds.
Trikeman89
04-29-2005 10:40:19
