Regular Flywheel Removal
Jeff_MI
04-30-2005 08:55:13
I have a Regular (1932 I believe). What's the best way to remove the flywheel? I thought of a gear puller, but someone mentioned there might be bolts that you insert and turn to help push it out. Thank you.
SproutW
05-01-2005 01:25:55
 Re: Regular Flywheel Removal in reply to Jeff_MI, 04-30-2005 08:55:13
I've had good success using two pieces of heavy angle iron and three pieces of threaded rod. I lined up one piece of angle iron across the two bolt holes on the flywheel and drilled the appropriate holes. Do the same with the other piece of angle iron but it will have one hole. The angle iron should stretch far enough to rest on both sides of the bell housing. Then screw in the pieces of threaded rod and screw down nuts on top of the angle iron. Make sure you use one turn at a time with each nut and you will slowly pull off the flywheel. The first time I did it I was alittle nervous I may hurt something internally in the motor but everything has always worked out fine. I'm still trying to find an easier way of putting on the flywheel myself.
Seiverttrees@aol.com
04-30-2005 18:31:06
And they go back on harder
Nebraska Cowman
04-30-2005 12:01:19
I use a big heavy puller that the feet hook to the 3 bolt holes. They do come off hard.
