H carb or gov.
JimBub
04-30-2005 15:49:12
The nut holding the linkage by valve cover came loose reassembled I hope correctly. Spring and metal piece was still there. Had gov. cover off and adjusted by sight. Now tractor will fire right off but when increaseing throttle a slow responce,then she surges high to low. Runs great at idle. Tractor has set all winter I"m thinkin carb, any ideas?
Wayne Swenson
04-30-2005 19:10:29
 Re: H carb or gov. in reply to JimBub, 04-30-2005 15:49:12
Warm up the engine and try readjusting the high speed mixture screw. Turn it in or out until it is running at its fastest RPM. Then turn out about 1/2 turn extra so it will not run lean while under load.
