oil in water
BEWILDERED
04-30-2005 18:24:38
I have never owned a red tractor before, but a man I work with has one for sale. He said it is a 500 series, I do know it has a six cylinder diesel i it. It is getting oil in the water, it shows up in the radiator but no water in the oil pan. What are the possibilities. He still runs this tractor from time to time and he says it runs fine. As I said I have never owned a red tractor, even my Massey is yellow. Thanks for the help in advance.
captaink
05-02-2005 09:59:13
 Re: oil in water in reply to BEWILDERED, 04-30-2005 18:24:38
I agree with Raffo that if you are getting oil in the water but not water in the oil, the oil cooler is the likely culprit. Both oil and water are in it, the oil is under higher pressure (about 35-40 psi) than the water (about 7 psi or so) so if a small opening develops internally, the oil will be pushed into the coolant before coolant shows in the oil.
Raffo
04-30-2005 18:33:42
I had a similar prob w/460 deisel,pretty much the same engine ,I think. The oil cooler was screwed,and letting oil in water,and water in oil! I bypassed the whole oil cooler. Check it first for bloating on sides from freezing.
jossette
04-30-2005 18:30:59
did you guys drain that into an oily bucket, then poor it back in.
cant have it in one place without the other???
Dakota Jim
04-30-2005 20:42:05
 Re: oil in water in reply to jossette, 04-30-2005 18:30:59
Sure you can. Either way. As it is, with regard to the original post, do yourself a big favor and forget about that tractor unless he is giving it away, and only then if you are seeking a lot of possible frustration.
