Order Farmall Cub Parts Online
CUB TIRE/WEIGHTS REVERSING
HERMAN MOORE
05-01-2005 10:51:06
I HAVE A '56 CUB TRACTOR WITH A 44 INCH BETWEEN CENTER OF REAR TIRES. I WANT TO WIDEN THE CENTER DISTANCE TO 52 OR 56 INCH. I UNDERSTAND I'LL NEED TO REMOVE THE WEIGHTS IN REAR. I'M NOT SURE WHAT I DO TO ADD THE WEIGHTS AFTER I REVERSED THE RIMS, OR CAN I ADD WEIGHTS AT ALL AT THAT POINT. CAN'T FIND ANYTHING IN MANUALS TO HELP. CAN ANYONE HELP ME WITH THIS? herman
Bigdog
05-01-2005 12:05:54
 Re: CUB TIRE/WEIGHTS REVERSING in reply to HERMAN MOORE, 05-01-2005 10:51:06
You can swap wheels, tires and all from left to right. The center opening on the weights is is big enough to clear the axle housings. One of my cubs is set up that way with the weights on the inside.
old
05-01-2005 11:15:36
Did that to a cub last summer, found it to be earyer to pull the tire off the tractor with the center bolts, lay them down take off the weights and bolt them back on before trying to put them on the tractor again. If you try to put the weights on after you put the tire on they are almost to much to handle, but if they are on tire/wheel its not to bad because you have more to work with and more leverage
