M gear case
e-manhunt
05-02-2005 12:07:00
Hello. After sitting all winter I removed the drain plug on the rear gears -got about 2 gallons of water and 2 gallons of a light brown concoction that would appear more normal coming out of a cappucino machine at a Starbucks.
Do I need 6 gallons gearoil or 13? Is there a special wrench to take off the fill plug? i can't find a socket driver big enough to fit (3/4" or 1"?) Where can I get a wrench for this?
thanks.
James H in Tx
05-02-2005 19:59:55
 Re: M gear case in reply to e-manhunt, 05-02-2005 12:07:00
I have a M that someone pounded a 1/8 inch by 1 and 1/4 inch flat stock of metal into the square side ways. It sticks up about 2 inches from the square hole. I just put a adjustable wrench on it to remove the plug.
James north of Houston,Tx
T.B.W.
05-02-2005 15:22:30
It takes 13 gallons on 90 wt. Got mine at wall mart. Take a bolt with a 3/4 square head and put two nuts on it and jam them together and use the head as a wrench
T.B.W.
05-02-2005 15:26:37
 Re: M gear case in reply to T.B.W., 05-02-2005 15:22:30
Also, if your M has a belt pulley, you need to take the side off to let the water out of there. When you refill, make sure you save about a quart and put in the belt pulley top
randy hall
05-02-2005 12:34:45
56 quarts
captaink
05-02-2005 12:10:53
Seems to me it’s more than 6 gallons, but can’t remember how much right off the top of my head. There is a level plug on the left side of the case close to the clutch rod. Fill the rear end until the fluid starts to run out of this plug. To get the fill plug out a ¾” drive should be close enough to get the plug out.
