Hydraullics
Sherry Metz
05-02-2005 12:59:00
Where do check the hydraulic fluid in 1960 460D Farmall tractor?
Joe Evans
05-02-2005 19:37:18
 Re: Hydraullics in reply to Sherry Metz, 05-02-2005 12:59:00
third party image
Check it at the point labeled #6 in the pic.
Aces
05-02-2005 15:55:58
Sherry Nat is right should be 2 places both on the left side on not the rear end housing and on on the TA housing either will do. The fill is the flat plate beside the gear shaft.
Nat
05-02-2005 13:58:18
Same place you check the rear end lube, I'm sure. The hydraulic system used the transmission and rear end as a reservoir on those tractors.
