belly plate?
hfarmall
05-02-2005 15:05:56
Is their such a piece called a belly plate? It"s on the bottom of a Farmall H, M, Etc. where the Hyd. pump would go if not mounted on top. Or should there be a pump in the bottom to.
n9lhm
05-02-2005 15:36:05
 Re: belly plate? in reply to hfarmall, 05-02-2005 15:05:56
Yes there is, the tractors that came from the factory without the belly pump had one to cover up the hole. It's called "clutch housing cover" in the M parts book, part #8027D. I put one on my MD since it had live hydraulics instead of a belly pump. I got it from Steel Wheel Ranch if I remember correctly.
Dave_Id
05-02-2005 15:33:39
Not all H's came with hydraulics, and the plate covered up the area where the belly pump would go. I do have one if you would be interested
208.582.1391
hfarmall
05-02-2005 16:08:19
 Re: belly plate? in reply to Dave_Id, 05-02-2005 15:33:39
I will keep your number and call you later. Thanks so much for your info. I have a lot of work to do on it.
