Super A Bearings
Peter Williams
05-02-2005 22:36:13
Can anyone tell me suitable replacement type bearings for teh gearbox and the governor on the Super A (1951-54)
gauger
05-03-2005 10:26:20
 Re: Super A Bearings in reply to Peter Williams, 05-02-2005 22:36:13
By gearbox I assume you mean the transmission. Most all of the linear ball bearings on the old Farmalls are metric and can be purchased at any bearing store. Just measure ID, OD and width in millimeters and ask your bearing guy for ABEC 1 rated bearings. With a few exceptions they will be MUCH cheaper than the dealer. The needle bearings for the governor rockshaft can be purchased for about $3 apiece, the three piece thrust bearing is a dealer item and I think it will run you about 20 bucks.
Bob
05-02-2005 22:46:06
There should be o problem getting them from a CNH dealer, and in many cases, the price is in line with other sources.
