Farmall H Shop Manual Source?
C. Amick
05-03-2005 09:30:39
I noticed that YT sells a I&T Shop Manual for a Farmall H. Is this manual a good one to buy or is there a better one available? All I saw on B i n d e r Books web site for this tractor was Service and Parts Manuals.
Glen E.
05-03-2005 15:16:42
 Re: Farmall H Shop Manual Source? in reply to C. Amick, 05-03-2005 09:30:39
My experience with I & T manuals is that you had better be a decent mechanic to begin with. The one for Farmalls, that I have, says "the procedure is obvious" way to many times. I was able to stumble through a rebuild on my M but I also had a parts book and the engine rebuild video, and lots of advise from other people.
Superih
05-03-2005 14:17:43
The best thing to get is an IH Service Manual for your particular model. They are quite extensive and will give you alot more imformation than the I&T Manual. There are several places that you can get reprints from. My local IHCase dealer had them. Yes that is the way the dealer should be named.
Harold H
05-03-2005 13:09:53
Three or four years ago you could still get all the IHC manuals from a Case/IH dealer. I don't know if they can still order the service manule or not. Good place to start looking.
Harold H
Duanes
05-03-2005 11:24:53
I prefer the Blue Ribbon manual. Ebay has some reprints quite often. It is the service maual that you want I believe.
RustyFarmall
05-03-2005 11:03:51
The service manual is probably what you want, but you need to contact them. I am sure they have what you need. Personally I find the I&T manuals very disappointing.
captaink
05-03-2005 11:15:30
 Re: Farmall H Shop Manual Source? in reply to RustyFarmall, 05-03-2005 11:03:51
Rusty,
I'm just curioius as to what you find disappointing about the I&T Manual.
captaink
05-03-2005 09:55:31
I&T are good shop manuals and will give you 99.998% of the information that you will need for an H. There may be better ones out there, but in my opinion I&T are worth every penny.
old
05-03-2005 09:55:07
The best ones to get would be from a case/IH dealer if, and thats a big one if they still have them
C. Amick
05-03-2005 11:11:36
 Re: Farmall H Shop Manual Source? in reply to old, 05-03-2005 09:55:07
Thanks for the advice. I have an I&T Manual that covers several different tractor models and it is pretty worthless. Perhaps the I&T manual listed for sale on this site by Y.T. that covers only one model tractor would be much better.
Nat
05-03-2005 13:56:16
 Re: Farmall H Shop Manual Source? in reply to C. Amick, 05-03-2005 11:11:36
If you've already got the I&T manual, save your money.
What you get from here is the exact same thing, except if yours has the yellow/manilla cover, the newer ones with tractor pictures on them have even less information in them!
old
05-03-2005 11:51:40
Not sure most only tell you enough to get by and thats if you know engines etc. The best I have seen are the ones that where printed by the company that made the tractor. I even have one very old owners manual that tells you every thing you need to do any thing to the tractor. But it was printed in 1935
