super m motor?
lafngas
05-03-2005 10:12:44
Ok i may not know all i need to about these things but I have a 53 factory lp gas super m it has a 264 motor but has a dip stick Is this motor correct i thought thay did not come out till the 450,s not sure it is a e code motor can some one help my dads 400 does not have one
Nebraska Cowman
05-03-2005 10:32:52
 Re: super m motor? in reply to lafngas, 05-03-2005 10:12:44
E code is 1959 so you can assume it was replaced.
captaink
05-03-2005 10:31:01
My M has a screw-in dipstick in the oil pan where the top petcock was located. I believe that this was an after-market option, but I do not know any details beyond that other than it is definitely quicker and handier than the petcock set up.
lafngas
05-04-2005 12:39:57
 Re: super m motor? in reply to captaink, 05-03-2005 10:31:01
this is in the block not the pan even has aplace for a fule pump like a w9 had it has a plate over it if its a 59 would it be a 450 or maybe a power unit motor i have been pulling it some and she never runs out at 5500 to 6500 just spins out
RustyFarmall
05-03-2005 10:59:11
captaink, that dipstick is an aftermarket item. It was manufactured by the Heiken co. Atlantic,Iowa. I have one just like it that I removed from my M for safe keeping.
captaink
05-03-2005 11:13:03
 Re: super m motor? in reply to RustyFarmall, 05-03-2005 10:59:11
Thanks for the info. I didn't know much other than I thought dad put it in after he bought the tractor.
