convert 350 Inter from 6 volt too 12
Ray350
05-04-2005 19:37:04
I have a 350 Inernationalutility and need advice in changing it over from a 6 volt system to a 12 volt system using an alternator. What type of alternator would work best? Also the proper wiring schematic.In addition I am looking for parts to hook up to the quick hitch for 3 point.
iester
05-05-2005 17:47:51
 Re: convert 350 Inter from 6 volt too 12 in reply to Ray350, 05-04-2005 19:37:04
I think mine came out with 12volt with gen. No hood cuts.Whats wrong with that???
little john
05-05-2005 03:09:26
I have one of those Japanese alternators still in the NAPA box if you decide to try that.
jwc1934@aol.com
TDK
05-04-2005 20:05:17
A Delco will fit without cutting or bending hood, although it is a tight fit. As soon as I get time I'll take a few pics of one.
old
05-04-2005 19:45:26
I'm doing that to a 300U, a delco alternator doesn't fit unless you cut the hood which I will not do. An alternator from a 1989 toyota pickup will fit, it wires the same as thye delco
Van in AR
05-04-2005 21:38:10
 Re: convert 350 Inter from 6 volt too 12 in reply to old, 05-04-2005 19:45:26
The Delco will fit, just need to turn the mount around and use a shorter belt. Have one on a 300, same hood size as a 350.
Van
old
05-05-2005 05:55:31
 Re: convert 350 Inter from 6 volt too 12 in reply to Van in AR, 05-04-2005 21:38:10
Ok let me say it this way, most delcos will not fit, there are a number of sizes of them and the common ones will not fit but the smaller one may, thats why I use a toyota one there small and they also fit with more room to move etc.
Gene Brooks
05-05-2005 14:12:49
 Re: convert 350 Inter from 6 volt too 12 in reply to old, 05-05-2005 05:55:31
I converted mine to 12 volt, put in a GM alternator an old one got it at a good price ,had to buy a 12 volt regulator for it and go to the trouble of mounting it and wiring it in and it was very tight under the hood of the 350 utility next time I'll buy the one wire Alt. make sure you get a ballist ressitor for your points for the 12 volts will burn them in no time;cuts the volts down to about 8 volts Gene
old
05-05-2005 18:19:20
 Re: convert 350 Inter from 6 volt too 12 in reply to Gene Brooks, 05-05-2005 14:12:49
I just did a 12 volt switch today on a 300U, I used an alternator from an Iszusu trooper, had a lot of room and used the same belt as the genny did. only needed 2 wires and a diode.
