second ID question for carb
RobertN
05-05-2005 20:24:07
My '41 A came with a carb that didn't fit right. It is a Zenith. The mounting flange is too big. It was mounted with two smaller bolts, instead of using the correct size studs. With studs, it was off about 1/8" , too wide.
The carb has a number on top, 108504. Is there any way to tell what model this carb is, and what it is for.
I took this carb off, and got one that fit correctly. That worked well for a while, but needs refresh, hence my earlier posting...
