I have pulled (and enjoyed success…) with my Super M at 5,500# and 6,500# in the farm stock class at local events over the past 10 years or so. Also my daughter in the “power puff” division – lady drivers only @ 5,500#. A few things we’ve learned: 1 – If you add weight to make a class, add it at the REAR of the tractor. Our experience is the SM loses traction before it lifts the front wheels or runs out of power. Ballasting at the front end gains us nothing. 2 – Don’t pull with a cold engine. If it’s not fully warmed up, let the motor idle so the temp gage is out of the “cold” band before you hook. 3 – Since you are running worn tires hope you get a hard track! We had our best success with worn tires on hard, dry tracks. After replacing with new Firestones several years ago we did best on wet/loose surfaces. If the track is loose, watch as other pullers go out ahead of you. If you observe soft spots try to avoid ‘em when it’s your turn. 4 – In the powder puff event, the drivers always seem more concerned with their looks than where they place. Hopefully that won’t be an issue for your son... Have fun and good luck!
