which heads for most power.
bradiniowa
05-07-2005 11:23:19
I have a distillate m, and want to make more hp. what is the casting number for the super m or 400 head. I believe those heads will give more compression. Thanks Brad.
REDEYE
05-07-2005 12:39:06
 Re: which heads for most power. in reply to bradiniowa, 05-07-2005 11:23:19
from least power to most power:
8060- high compression m ??cc?
8574- high compresion smta ??cc?
362174R- 400-450 gas 180cc?
364586R- 450 lp 120cc?
bradiniowa
05-07-2005 13:27:11
 Re: which heads for most power. in reply to REDEYE, 05-07-2005 12:39:06
thanks for the response. will the the 400 heads fit the m block without any modifications. and where do I look to find the casting # on the head.
RustyFarmall
05-07-2005 14:30:06
 Re: which heads for most power. in reply to bradiniowa, 05-07-2005 13:27:11
They will all interchange readily. The number is on top of the head, under the valve cover.
