cracked head
MDJim
05-07-2005 16:43:40
i have a head out of a 1948 MD that is cracked. can it be refurbished and reused? i don't want to junk it if it can be fixed.
MDJim
05-07-2005 19:02:38
 Re: cracked head in reply to MDJim, 05-07-2005 16:43:40
thansk for the info guys. i appreciate it.
Lance R.
05-08-2005 11:20:51
 Re: cracked head in reply to MDJim, 05-07-2005 19:02:38
El Toro is right. I've heard that Midwest Cylinder can just about fix any head to as good as new.
pgonthwng
05-07-2005 18:46:02
check out lock and stich .com for info on crack repair. I work in a diesel reman. company and use their stiching pins on 7.3 and 6.9 navistar heads as well as 5.9 cummins. if you can drill a hole and tap it you can probably repair it yourself. make sure to pressure test the head.
El Toro
05-07-2005 16:53:05
Check with your local welding shop to see if they
have ever repaired cracked cylinder heads. You can contact Midwest Cylinder Head Company in IA.
Their toll free number is 1-800-873-8506 and their
email is midwestcylinderhead@aol.com Hal
