330 trasmission gears and bearing
Nebraska Cowman
05-08-2005 06:54:09
The big gear has a tooth chipped, my mechanic says he can weld and build it up. the roller bearing above is what went out and caused the trouble. Glad it is not worse.
third party image
r4etired
05-08-2005 18:13:16
 Re: 330 trasmission gears and bearing in reply to Nebraska Cowman, 05-08-2005 06:54:09
Cowman, If we could see how many bull gears were chipped in the tractors we use every day, We would probably be afraid to use them.I would be very skeptical about welding on a gear,If it is'nt reground perfect it will probably break just below the weld,and you will have a pretty good size chunck traveling in your rear end.
DWV
05-08-2005 07:43:05
If you need a good gear I can fix you up at a reasonable price.
Nebraska Cowman
05-08-2005 10:37:08
 Re: 330 trasmission gears and bearing in reply to DWV, 05-08-2005 07:43:05
ok, thanks, I'll keep it in mind
