TA rebuild
REDEYE
05-08-2005 08:50:15
where can i buy a kit to rebuild a TA? I have seen rebuilt ta's for sale but not kit. also has anyone ever used a sprague type TA and are they much better than ramp and rollers?
Hayfarmer
05-08-2005 09:00:43
 Re: TA rebuild in reply to REDEYE, 05-08-2005 08:50:15
I don't think I have seen a TA rebuild kit advertised. Sort of depends upon what you need in it. When I rebuilt the one on my SMTA the clutch disc, pressure plate and throwout were ok, needed ramp and rollers. I got a rebuilt ramp and roller setup from Steelwheel Ranch I think. I could have gotten a sprague type setup from them but was more expensive as you had to change carrier also. I had good luck with mine but I am the primary driver and I don't abuse it. Not hard to rebuild in my case, if you had problems in sun gears or that part would probably get to a rebuilt really quick.
PAULIH300
05-08-2005 09:17:41
 Re: TA rebuild in reply to Hayfarmer, 05-08-2005 09:00:43
I have noticed that some TAs used chrome plated rollers,and these TA units arent supposibly using the same parts as the later,non-plated parts.Early 300s are among those with the odd setup.Dont know whats different besides a little plating,but supposibly IH literature says they arent interchangeable.So,that would make a TA rebuild kit a little difficult,as the first few thousand 300s (and maybe others)would need a different "kit".
