560d injection pump timing
JA
05-08-2005 10:58:34
I had a governor failure and pulled my pump for overhaul. While it was out one of my grandkids entertained himself by playing with the injector pump drive gear. It is completely out of time and will not even fire. How do I get back in time without pulling the motor. This motor was rebuildt less then 500 hours ago and I hate to pull it again. I have tried going to tdc and 3 degrees but am unable to find any marks on the other gear to line up on.
Aces
05-08-2005 17:28:23
 Re: 560d injection pump timing in reply to JA, 05-08-2005 10:58:34
JA The pump drive gear is held in place by a bumper spring in the end of the injection drive shaft, with the pump off I think one could get the teeth to jump timeing and if that is the case I would think you would have to pull the timeing cover to see the timeing marks. You can turn the motor over until the marks line up on the crank, cam, idle gear and them time the pump gear. Don't see any other way.
