Duckbilled F-30
Rgriff24
05-09-2005 03:25:27
Hey Sloroll, I found the serial numbers you told me to look for. The number on the frame is FB 2098 and the number on the block is 2143. I hope this will give me more info. Also, as I was scrapping paint away so I could see the numbers, all I saw was red paint. No grey underneath.
Thanks
Sloroll
05-09-2005 09:45:13
 Picture Duckbilled F-30 in reply to Rgriff24, 05-09-2005 03:25:27
third party image
Nice!
Rgriff24
05-09-2005 09:47:31
 Re: Picture Duckbilled F-30 in reply to Sloroll, 05-09-2005 09:45:13
Thanks for the help with the pictures. I'm going to figure this out yet.
Rgriff24
05-09-2005 09:25:37
 Re: Duckbilled F-30 in reply to Rgriff24, 05-09-2005 03:25:27
here's a side veiw of the F-30
Sloroll
05-09-2005 03:42:49
You have a 1932 Duck billed F-30. It was almost certainly painted gray origionaly. Sometimes it is very difficult to find the gray. That frame number and block number tell the story. Someone probably replaced the tool box with another. That is an easy fix. You got a good one bud.
F-Dean
05-09-2005 04:58:39
 Re: Duckbilled F-30 in reply to Sloroll, 05-09-2005 03:42:49
Van Sickle makes it. They are located in Lincoln, Nebraska. Just call the 1-800 number on the "Rattle Can."
rgriff24
05-09-2005 05:10:56
 Re: Duckbilled F-30 in reply to F-Dean, 05-09-2005 04:58:39
Van Sickle makes what?
Rgriff24
05-09-2005 03:48:14
If I can figure out how to post pictures I will. I have some on a floppy disc that I took yesterday. Also, the person my dad bought this tractor from told him that his dad bought it new in 37. I'm kinda confused now.
Thanks for the help.
Sloroll
05-09-2005 04:04:08
 Re: Duckbilled F-30 in reply to Rgriff24, 05-09-2005 03:48:14
It is possible it sat on the lot for a long time, the dealer lied or your friend was confused. My dad bought a new hay rake in 68. I was so proud of that rake because it was the only new thing on the farm. I found out a couple years ago it was used..... It looked new to me!
IHMAN3388
05-09-2005 05:47:41
 Re: Duckbilled F-30 in reply to Sloroll, 05-09-2005 04:04:08
The F series were painted Farmall red from 37-39. That was a long time ago and somebody may be getting dates confused. Exactly what is the story behind "duckbilled F-30s"?
IHMAN3388
Rgriff24
05-09-2005 04:33:56
How do you post pictures on this site?
Sloroll
05-09-2005 04:55:51
 Re: Duckbilled F-30 in reply to Rgriff24, 05-09-2005 04:33:56
What I do is got go "Tractor OPhotos" (to the left on this page) And follow it's instructions to post the photo there. Once the picture is posted right click the picture and chose "Properties" Copy the photos address (It will end in jpg) then when you make the post here, copy that address to optional image URL below the post. You don't have to use the "Tractor Photos" if you post pictures somewhere else on the web. You will still select Properties from that site and post the same way.
Rgriff24
05-09-2005 06:13:15
 Re: Duckbilled F-30 in reply to Sloroll, 05-09-2005 04:55:51
Let me try it again
Rgriff24
05-09-2005 05:56:08
Here's a picture of my Duckbill
Sloroll
05-09-2005 06:27:49
 NICE TRACTOR!! in reply to Rgriff24, 05-09-2005 05:56:08
third party image
Hope you don't mind. Yup, that is a ducky! It should be ray but who cares. I sure looks nice! Looks to be in great condition too.
In answere to a previous post. The Duck billed 30s and 20s were the earliest of the F series before they went to worm and pinion steering. The F12s lead the way with the worm and pinion in 33 or preproduction 32s.
RGRIFF24
05-09-2005 09:29:24
 Re: NICE TRACTOR!! in reply to Sloroll, 05-09-2005 06:27:49
Try it again
Rgriff24
05-09-2005 07:02:16
I will try to post another picture I have shortly
