rust in 806 injection pump, wrong filters?
mbutts
05-09-2005 05:50:44
had a pump come in that has fine rust in it. very gritty and so bad that just about everything was gummed up. customer tells us that the parts store only gives them 1 number for both primary and secondary filters instead of a canister filter and a sock filter. anybody care to comment on where to get good secondary filters? we are assuming the rust is coming from the fuel tank. or could a hose past the filter be deteriating that might have steel braid in it? I think he gets his filters either from napa or car quest. are there better replacement filter numbers he should be looking for other than what they cross out of the book? tnx, martin
caseyc
05-09-2005 08:38:32
 Re: rust in 806 injection pump, wrong filters? in reply to mbutts, 05-09-2005 05:50:44
go to case/ih and get the filters....much better and not a whole lot more money if any. i'm not positive on the 806's but my 766 uses two different filters, one primary and one secondary.
casey in SD
