timing my H ?
arod
05-09-2005 14:00:29
so, point rotor at the cylinder that is in firing position. then tighten the distributor down at the moment the points open by using a voltmeter to show the current drop off? That easy right? yeah right, hope so!
TomH
05-09-2005 18:36:34
 Re: timing my H ? in reply to arod, 05-09-2005 14:00:29
Make sure the cylinder you're looking at is on the compression stroke and not exhaust.
riverbend
05-09-2005 17:44:24
That should get you close. If you pull the coil wire out of the cap, a spark will jump at the exact instant the points open.
Your H has timing marks, why not follow the procedure in the manual ?
