International D239 Neuss Diesel
CND
05-10-2005 15:48:28
I have a D239 German Diesel engine in my 260A backhoe that slobbers, spits and smokes out the blowby tube. If the engine is warm and I work it hard it lets out clouds of oil. It runs great although is a little hard to start. I am figuring it needs an overhaul so can I get the parts from IH? Is it expensive? This hoe has sat around a lot and done odd jobs on a farm for quite a while owned by an older guy it probbably hasn"t seen more that 12 or 13 hundred RPM in many years, certainly no load. Would this engine clear up just a little bit if I worked it at a good load and rpm for a while? I would like to wait to overhaul it until this winter when I have time. The blowby is unacceptable as it is.
Any other info on this engine or backhoe would be great!
Thanks,
JB2
05-10-2005 20:50:54
 Re: International D239 Neuss Diesel in reply to CND, 05-10-2005 15:48:28
Hi Yellot, the D239 is used in 574,674,684 farm tractors. Since the engine has a lot of blow by out the crankcase breather it could be caused by a stuck or broken ring.
But don't overlook the simple things first.
Good luck
JB2
Yellott Canby
05-10-2005 18:57:15
Hello,
You can get the parts a lot cheaper from a ditributor of repower kits then from IH. Try BTMC corp or Worthington Ag parts. I have bought several kits from BTMC.They are good US made parts, Cleavite I think. I think the one for that motor runs $650 or so.YC
wolfmantractor
05-10-2005 17:59:57
Don't overlook the obvious like air cleaner filters & the pump setting. I have a 239 that suddenly got weak & slobbered and I found the fuel shut-off, advance cable had come loose & unadjusted itself. A minute with a screwdriver & she smoothed out like new.
John in WV
05-10-2005 17:01:42
Have your injectors checked, change engine oil, change water thermostat to 195 degree.
