M rpms up down under load.
Richard Fazio
05-11-2005 10:40:06
I was using my M the other day to plow with a three bottom in pretty heavy soil. When under a heavy load and the throttle up near full the RPMs were pulsing up & down. Like I was giving it gas then backing off and right back on again every couple of seconds or so. With no load or a light load it doesn't do it. At lower throttle settings it doesn't do it. I'm thinking it's the governor but where to look. Could it be just and adjustment or do I need a rebuild. I want to get it running right cause I'm planning on bringing it to a local antique pull. Thanks for any suggestions.
Richard Baugher
05-17-2005 07:52:04
 Re: M rpms up down under load. in reply to Richard Fazio, 05-11-2005 10:40:06
I am pretty sure all you need is a little stronger spring on the governor.
jossette
05-11-2005 10:43:49
if you have the carb with the screw on the bottom, crank that out a turn or two and try again.. heavy work requires more fuel,,,,
RustyFarmall
05-11-2005 13:34:53
 Re: M rpms up down under load. in reply to jossette, 05-11-2005 10:43:49
Very slight possibly adjusting the carb will help but I doubt it. I think it's time for some governor work.
Richard Fazio
05-11-2005 10:45:45
Wow! quick responce Jossette. I didn't think of that one. Good idea I'll check that for sure. That would be nice and easy wouldn't it?
jossette
05-11-2005 11:04:15
 Re: M rpms up down under load. in reply to Richard Fazio, 05-11-2005 10:45:45
that screw should be almost all the way in for puttin around. grandpa always turned out before heavy plowing or discing....
